Thought I would share my setup to stop spilling antifreeze on the ground. I searched TC and saw lots of different methods used by others to take care of this issue. I liked the idea of hiding the tank inside the fender by the battery but didn't want to drill holes in the fender. I also wanted access to the top of the tank and to be able to see the amount of fluid in the tank. I bought two different aftermarket kits which I discarded for various reasons. I decided that I would go to a wrecking yard and see what I could come up with.
I came home with this tank from a Honda (pulled several different ones and I'm not sure what model or year I used). The tank holds 42oz of antifreeze. I also removed the mounting bracket from the donor car.
The tank was pretty gunky inside so I used soap, water and BB's to get it clean inside.
I needed to cut off part of the battery tray to install the bracket and drill a hole through the tray and the inner fender to attach the bracket.
I also modified the tank cap for a better fit and look.
From this.
To this.
The tank installed without the battery
The end result.
From this.
To this.
The end result.
