New member looking for info or suggestions on kits to convert 65 plain Jane to power dual brake system.
Jim
Jim
Well, all Chevelles went to dual master cylinders in 1967, but it might be hard to find "original" parts for a '67 that are still in good shape, as they are going to be nearly 50 years old...Yes I am keeping the drums for now. I just want dual reservoir MC vac booster and lines. Is there original parts that will work, perhaps a later year?
Thanks for the suggestions, the link does not work for me.
Jim
Dual Master Power Drum
Upgrade Dual master cylinder BOT03 BLK102 BLK102LP
BLK102LM DBL01 ADJP01
and booster with four wheel drum
brakes. New dual master lines
and dist block located below the
dual drum master and bolted to
the frame in the stock location. All
other factory lines will work.
DBK6404
'67-'72 came with the dual master, and drums were available. Pretty much any 67-72 GM A-body parts will swap ( Chevelle, Cutlass, Skylark, Lemans...). depending on just how "period correct" you want to be, the later systems used a different looking booster. I also think in 1967 (or 1968), GM started using a distribution block which may also have a switch for the brake light on the dash (earlier years, the brake light on dash is ONLY controlled by the parking brake)... So using a used setup for a later year, will have some parts not functional and/or not hooked up anywhere. Probably have to fabricate or purchase other lines and junction blocks/unions to splice in a later setup.Jim '57 said:I know very little about the Chevelles so if there is a later year that had power drum brakes but with dual reservoir, that will work on my 65.
