Hello gang.
I'm going to use AFR 305 cc heads. I have noticed that the chamber at it's widest point is wider than the bore, which in my case is 4.32".
In the old days, GM used to notch the top of the bores...for valve clearance? Or was it for airflow?
I'm wondering if the overhang hinders airflow???
Years ago on a 427 we built, we used a die grinder to releive the tops of the bores to aid airflow. That engine ran damn hard for what it was.
Just thinking outloud, but I've often heard that bigger bore unshroud the valves and give better airflow.
Comment?
I plan to discuss this with my engine builder.....
Ron
Comment?
Ron
