Hi all,
To follow up with my dyno thread, I thought it might be better to make a new one with the combo swap. As it’s clear I need help, please bare with me as I try to wrap my head around this stuff. I have the ability to work on my motors myself, but am far from an expert and am learning every day.
A bit of info….. (please let me know if you would like more)
My goal is to make 500 +/- rwhp.
The car will be driven on the street 99% of the time, with the exception of hitting a road track every now and again.
I drive the car to work (30min each way) and the occasional road trip (up to 1000 miles round trip). I live in the great white north so I only get use of the car 6-8 months of the year….leaving me a few months in between to do work on the car without sacrificing driving time.
SO here we go: It has been suggested that I change HEADS/INTAKE & CAM. Current set up is in my sig. I was told by the engine builder I had 10:1 compression ratio, but he also said I had a 600hp engine, so this means nothing. Current HP rating is 365 @ 5300 rpm and 409 ft/lbs of torque @ 3800 rpm.
So far I have the following suggestions for parts. (FYI this is a GEN V block)
-Brodix race rites heads- Need to know what size would be best suited for my needs.
-Edelbrock RPM Performer or AIR gap intake- Picked up an RPM Performer (used but in good shape).
-Comp Cam 11-451-8 (PRM range 2200-5800, IN 230, EX 236 @ 050 lift)
I still have a Lunati VooDoo cam and lifters I had bought for a previous engine, but was never installed. Spec’s are as follows: part no: 10110702, RPM range 1400-5800, IN 219 EX 227 @ 050 lift. Will this be sufficient, and will this cam work in a gen V block?
I have also been searching my local classified adds for used heads, but am leery about buying as I don’t know what I need. I don’t what heads that are way too big for what I have etc… I have found a couple that seem like a good price, and will post the info if someone will guide me through…
Again, if you want more info just let me know and I will do my best to provide it. Much thanks guys!:beers:
ken
