I’m working on a 69 Chevelle. I’m in the processes of converting the column shifter to a console shifter. I don’t know a whole lot about these older cars so I will try to give as much information as possible. The steering column non tilt and the new console shifter is what I think they call a horseshoe shifter. I had planned to leave the linkage connected up to the column after the conversion. This way I could keep the trany locked when the ignition is turned off and not have to fool with the backup lights. Is it normal to leave column linkage connected? After being close to done I have discovered that the travel is different between the two shifters. It appears that the column shifter has the shorter travel. Has anyone else dealt with these same troubles or have some helpful info to give me?
