I have a TH400 with a column shift. I do not want to change it to a floor shift because I am trying to keep the car as ariginal as possible. Is there anything I can do to modify it without it being visible? I know there is an under/overdrive available that has a floor mounted switch like a high beam switch which can be used to shift the trans. Any suggestions?
