I am doing a auto to 4 speed conversion on my small block '67.
I used a bolt screwed into the ball stud hole to use as a guide to place the z-bar frame bracket. With the z-bar located at this ideal spot, the clutch adjustment rod hits the headers. The only way to make the adustment rod clear would be to install it on the engine side of the z-bar arm(maybe not good alignment to clutch fork) or lower frame side of z-bar bracket, which may cause binding.
Has anyone experienced this?
Thanks- Rob
Thanks- Rob
