I need a clarification on what constitutes
a numbers matching Chevelle SS. I will apply
the facts to my particular case wherein I am
purchasing a 67 Chevelle SS with a "numbers"
matching engine and Muncie 4 speed trans.
In this case the 1967 Muncie 4 speed is currently out of the engine since a small
hairline crack in the aluminum case is present (apparently repairable). I checked the numbers on the transmission and it was
the transmission made in May 67, same as the
396 engine.
Meanwhile, a Muncie 4 speed transmission from
a 1970 Chevelle SS is in the 67 Chevelle SS
and works great. The seller will give me both
the original 67 transmission (he is having the case tig welded) and the 70 Muncie trans
already in the 67 Chevelle. He has also agreed, if I want, to install the original
67 Chevelle SS trans in my 67 Chevelle if I
want and at no cost (once it is repaired).
My questions are:
a. When they talk about "numbers" matching.
Does this mean same engine and transmission
year or does it mean same casting number
series.
b. For example, many guys (or ladies) may
have romped on the original 4 speed trans.
in a Chevelle SS. So, if the owner puts in
a new rebuilt trans from a 68-70 (which is
also a Muncie 4 speed)-- is this considered
correct. Or, does a number matching mean it
must be engine and trans from same year for
same vehicle.
c. Finally, am I making a big deal out of
the distinction between a 67 Muncie vs. a
perfectly useable 70 Muncie.
d. Does a 70 Munice 4 speed in a 67 Chevelle
detract from value of vehicle.
Thanks for ending some confusion on "numbers
matching" and what it really means in the
Chevelle market.
Ken McD...
396 engine.
My questions are:
series.
same vehicle.
Chevelle market.
Ken McD...
