Mike,
You and I agree on a lot of things. I agree with your definition of the CE letters as for Chevrolet Engine, and I agree these were used for warranty service, but I am sorry, I cannot agree on the non-useage in the parts system. Can anyone remember ever seeing a correctly broached non- numbered clean pad ? (Post 1967, as I have seen some previous to that year). I have seen a lot of engines and have never seen one. I have, however, seen many CE Engine blocks, including numerous NOS examples, some of them in crates. I cannot buy the usage of them only for warranty, although that was the real reason for the number to be there. This replacement CE was also still under warranty if used for a warranty purpose and a way needed to be devised to identify it. So the code was there for warranty, but many people who were racing, etc, still could buy a CE over the counter. With your theory, this would require them to make and stock two different engine block assemblies, one CE, and one without, even though they would essentially be the same. This makes no business sense. And keep it around 5 years, I'm sorry, that just did not happen, as you got the years block that available when it went bad. They would not stock warranty engines and then just put them in parts service years later. Can you imagine the room this would require? Also, if warranty count was the only reason to use a CE code, then the same would apply to completed engines which are coded with a suffix just like a production line engine. No attempt was ever made to seperate the warranty replacement engines from the ones purchaced over the counter. Why were they not specially coded so warranty could be tracked? These complete engine assemblies were available and would be used if the engine blew up so bad that none of it was useable. If the bottom end went, than only the CE was used. Now as for your guy in Chevrolet management, I too, love to get opinions from the people who were there. But I always take them in context. It may just be what they know about a particular subject, or what they remember after about 40 years of time has passed. But I have uncovered plenty of things they told me did not exist before, this would not be the first. And as I said before, that was the primary reason a CE code was there. But I have an engine that was not for warranty, and I have seen many others. I usually trust what I find and authenticate. Also, and I may be opening up a can of worms here, but just like you could buy a fitted block, you could buy a bare Muncie trans case. All of these, and I have seen quite a few more than motor blocks, are CC coded, not CT. The CT was probably reserved for a complete trans, and the CC for a bare case. These definately exist and were sold through parts service. The sheer number of them that are out there, no way they were all for warranty. Anyway, that is just the opinion of this "Crazed Enthusiest." Been called worse, by the way. But debate is good, that is how we all learn. That what TC is about, isn't it? And I would not expect us all to agree, but I will always be willing to keep an open mind if you guys will. Unfortunately, this stuff is old enough that the truth often gets lost in opinions, as there is not many factual ways to double check information. This is one of those cases. Sometimes we may have to respectfully agree to disagree. Hope you understand.
Jeff Dotterer
Dated Components
Diamond Restored Judge
