AL, you'll want like 18° initial with that cam. another 18° mechanical advance will give you 35° total, if your distributor has a vacuum advance another 10° vacuum would be good.
From your PM I see that you have a 4 corner idle carb. I recommend you warm up the engine completely and start tasking 1/4 turn at a time out of all 4 mix screws. That is, screw in all 4 a quarter turn see what happens to the idle. before starting run them al in to seat and count the turns. average the turns to seat and set them all at that number, then start leaning them out. pay attention to the idle quality, if it starts bogging down or idling rougher you're close to the end.
look at the throttle plates, see if you can tell if the front and rear are open about the same.
Let us know what happens.
