The VERY, VERY, VERY first heads with the double humps, as already mentioned, were introduced in 1961 on the 315hp/283 with Fuel Injection. Those heads were ONLY on the 61 FI engine (thus the origin of the term "Fuelie heads") and they had 1.94/1.5 valves and also as mentioned, they were the 461 (and 461X) castings. These heads continued up through 63 on the 300, 340 and 360hp 327 engines and all of them ONLY had the 1.94/1.5 valves. THEN, in 1964, these same heads came with either 1.94/1.5 or 2.02/1.6 valves, depending on which engine they were to be installed on. The 300hp/327 got the smaller valves and the 365 and 375hp 327s got the bigger valves. The 350hp/327 didn't come out until 1965 and for all practical purposes it was the same engine as the 365hp version, except, it had a hyd cam. The 62-3 340 and 360hp versions had the original "Duntov" solid cam (which first cam on the 57 270hp 2x4 and 283hp FI engines) and then the 64-5 365 and 375hp versions got the 30-30 cam. So, BASICALLY, the 340hp version of 62-3 and the 365hp version of 64-5 were the same engine except for the bigger valves and bigger cam. And the same goes for the 360hp of 62-3 and the 375hp version of 64-5. The lone difference is the 350hp (L-79 as many refer to it) version which continued up through 68.
A solid lifter small block did not return again until the 67-69 302 Z28, and then the 70-72 LT-1/Z28. The 70-72 LT-1 and Z28 engines were identical. The LT-1 in the Vette was rated at 10hp more than the Z28 version supposedly because the exhaust system of the Vette was more efficient than that of the Camaro.
Now, this brings me to a question. Why did the 350hp/327 become so very well known as the L79, but yet VERY FEW people know that the 375hp FI engine is the L84? Its strange how the RPO number for some engines stuck, but yet it didn't for others. Another example, NO BODY calls a 65 Chevelle with a 396 an SS396, virutally everyone calls it a Z16. Same thing with the alum headed 427 of 67-69 and the 69 solid alum 427. Everyone refers to them as the L88 and ZL1. Like I say, the RPO sticks for some, and not for others!
