I'm confused on what I should use...Solid roller,gear drive,stock tin cover. Do I want a nylon button or aluminum or torington.And I want .005 clearance?Right?
BBC I assume? Stock BBC tin cover is supposedly good/firm enough for a cam button. Use nylon, it is cheap, easy to set and has no parts that can fail and end up in your oil pan. .005" is fine, probably as tight as you want to go. .004" - .012" is OK. (My limited opinion/experience of course)
