... I am having some serious starter issues. After an hour of running or so my starter just wont work without a half hour or so of cool down time. I just replaced it yesterday w/ a new one and within a couple hours it was doing the same thing,
What symptoms?
Slow cranking (Try and see if the dome light dims while trying to crank)? Or made an audable "click" from the starter, but slow/no spinning? This can be "Heat Soak" where the bushings in the starter motor have expanded enough due to heat that they are binding on the shaft... Can be made worse by bad cables and connections and headers.
Is there no sound at all when you turn the key? This could be a bad solenoid or the wire to the solenoid having too much resistance, to the point where its not allowing the solenoid to engage (which also switches the main power cable to the actual starter motor)... In this case, the main starter motor might be fine, just the solenoid is too hot... Another case for clean connections, etc...
Since the car never had these issues in the 80's, yet still has them after replacing the starter, I'd lean toward replacing the cable and cleaning all connections... I was checking the other day, and Summit has a Stainless Steel starter shield listed for $7, might be worth adding on the next time you drop the starter out, and maybe some insulation for the small purple wire down to the solenoid...
cobaltchev67 said:
Another good thing to have is a starter bracket.....I had to make my own bracket for the mini-starter and bolt it to the GM bracket. It'll prevent you from bending starter bolts and keep everything where it's supposed to be.
A little clarification for anyone unfamiliar with this "bracket" (future topic searches, etc). GM used a small bracket on the very front of the starter motor (At least on Big Blocks), and it bolts to a boss cast in the block (near the dipstick tube on a BB)... Usually a PITA to get to with headers...
Wrapping the headers near the starter can make a big difference in the heat the starter sees, BUT it can cause problems with the headers. The extra heat can cause the header tubes to become brittle and crack. this might be worse because of the age of the headers...
