1 - 3 of 11 Posts
94,
As John mentioned, I've got a set of Brodix 18X's. Check out the Brodix website for flow numbers on the standard version and the M2 CNC version.
There is more in them even over the CNC version, but it takes quite a LOT of work. Probably in the neighborhood of 80+ hours porting and 3 flow bench sessions. Not to mention I had a GREAT deal of guidance from one of the premier Pro Stock head porters in the country.
I should get the heads back from a fresh valve job and resulting flow numbers on Tues. and I can give you the final flow numbers. Final runner volume is in the 256-258 cc range. I need to remeasure when I get them back. You can see some of my home port job and engine details on my website:
http://hometown.aol.com/jgchevelle/engine.html
It will likely be several months before I get the engine on the dyno as I'm in the middle of moving and my wife has PLENTY of projects that I've been told take priority over finishing the engine. It is KILLING me knowing I have everything except the pushrods to complete the engine and no time to work on it. I'm shooting for between 730-750 honest HP @ 6800 RPM and around 640 lb-ft TQ.
In general, the 18X fall right in the middle of a 23 degree head and a true 18. A good 18 degree head is about 100 HP better than a 23 degree head. The 18X's are about 50 HP better than a 23 head. Again these are generalizations.
If I had to do it again, I would pony up and just buy a set of std. 18 degree heads and the shaft rockers that go with them. The pushrod restriction really holds the 18X head back. It is what it is.....a compromise.
Save
94,
I can only hope the dyno numbers posted on Brodix' site are correct as my heads should have about 20 cfm. on the 18X CNC version. Without knowing the details I may be a little premature, but the TQ numbers shown really don't make sense. 748 lb-ft @ 4600 RPM?? That seems awefully high. 2.32 hp/cfm also makes me raise an eyebrow. I'm not saying it isn't possible, just not likely. If it is true, that is one REALLY nicely worked out combo.
On alcohol maybe??
I hope I don't seem like too much of a killjoy, but with all of the inflated claims/numbers floating around the net these days, I don't believe much of anything until I see a vehicle go down the track or the numbers are coming from a shop I know I can correlate track numbers to dyno numbers. Those are few and far between. I would consider Wolfplace one of those. As the old saying goes, "If it looks to good to be true, it probably is."
You might call Cropper Automotive and get some more details.
Let us know how it works out for you. I will post dyno and track numbers whenever that day finally comes around. It may be a long wait though.
Save
Final flow numbers on my "home ported" Brodix 18X heads.
Before: (F&F ported - Canada)
.200 - 146
.300 - 205
.400 - 260
.500 - 303
.600 - 327
.700 - 332
.800 - 330
After: (home ported)
.200 - 144
.300 - 203
.400 - 261
.500 - 306
.600 - 334
.700 - 351
.800 - 359
.900 - 361
1.00 - 363
Save
1 - 3 of 11 Posts
