i have been toying with the idea of making an engine stand that has the engine bolted on top and an electric motor on the bottom. then i would connect the electric motor to the engine via a belt. this way, i am assuming of course, you can run the electric motor at a specified/varied RPM and break in the cam without the risk of overheating/hard starting/long cranking times/bad timing/fuel problems etc. after you have run it for 20-30 minutes and the cam is broken in, you can pretty much take all the time in the world to drop the motor in, solve cranking problems and fine tune the setup. you dont even need to have all components hooked to the engine. you could do this to a bare long block even.
I would really like to hear some feedback on this. do you think it would work? has anyone done this, or something similar, before?
i cant add attachments, or i would post the sketch i have made for this idea.
