I recently bought a power disk brake conversion system from Ausley's Chevelle Parts. It seemed to have worked fine for a hundred miles of driving or so, but then I got in the car today to take it for a spin, and noticed as I pulled out of my driveway the pedal went to the floor and I barely had any brakes. I drove around the block, and things did not change. I didn't go over 25mph, but I had to stand on my brakes to get the car to stop.
I then pulled it into the driveway, and saw some brake fluid that had leaked onto my inner fender. I then did some checking, had had my wife step on the brakes, while I looked at the master cylinder area, and there is a nut on the very front of the combination valve that is leaking brake fluid when the brakes are applied. Not a lot of fluid, but probably about 4 or 5 drops each time the brakes are applied, and apparently enough for me to have almost zero brakes.
Does it sound like the combination valve is shot on this thing, even though it is brand new along with the rest of the system? I don't know what else the problem could be. I tried calling Ausley's to find out what kind of valve it was in case I need to replace it, but nobody answered so I left a message. Would this system need the exact same model combination valve that I bought from Ausleys, or would any work? Your help would be greatly appreciated with this frustrating problem. Thanks Shawn
