The first thing you need to know is the compression ratio of your current engine. When you add a blower you are basically raising the compression of the engine. If you currently run on 87 octane you can add a few pounds of boost and go to 91 octane. If you currently need 91 octane you will need to mix race gas with the pump gas to take advantage of the blower.
This is the basic of basics in regard to this as there are other factors such as intercooling, changing the cam, adding alcohol injection and pulling out timing that can allow for more pounds of pressure. However the compression is the real starting point and from there you need to address things such as type of piston, fuel delivery, type of blower, and cam.
