I have a Performance ZZ454 crate motor with about 3k miles on it that i went to start up the other day as the Florida weather has cooled and the perfect time to fire it up. As i was cranking it, the carb shot a deluge of fuel up through the carb and down through intake and backfired. I let it sit and inspected the carb, fuel was leaking around carb. found the diaphragm had a split and caused the issue.
Repaired carb reinstalled and as soon as it started i heard the engine knocking. Thinking this may be unburnt fuel i let it idle for a minute...didn't subside. I shut it down drained oil and checked for metal...none...opened filter and inspected no traces at all. I did engine compression test on all cylinders..all at 165. I changed plugs, changed oil as it smelled of fuel. Started it back up and knocking is still there, when i was cranking engine without plugs in it to visually observe valvetrain movement i did not hear knocking.
Suggestions before i pull the heads ??
