Bellhousing alignment question
904 views 4 replies 4 participants last post by  Chicken Coupe
Planning a few weeks ahead, been searching and reading, need a few questions answered.
Bellhousing alignment- grabbed/printed several posts on the process, but how do you center the magnetic base on the flywheel? None of the articles mention how.
Thanks in advance! :thumbsup:
#2 ·
Don't have to
Anywhere it will grab, will be fine.
As you are turning the flywheel----all you are doing is checking the runout of the bellhousing.
This measurement will be the same wether or not the indicator is centered
#4 ·
Just stick the magnet anywhere stable that allows you to get the indicator setup right.
I prefer to do it without the disk or pressure plate installed, and stick the indicator base magnet on the flywheel's friction surface.
