Ok, so I'm stuck rebuilding the engine in my truck, and I'm starting to lose it while figuring out bearing oil clearances...
I used standard size replacement bearings, which when checked gave me .0010 oil clearance, the high end of the clearance range (.0010-.0025).
Two of the bearings are spot on at .0010, the back two are just higher than that. Starting with them at .0010, then any wear will begin to take it out of acceptable range, right?
Now, if I swap up to +.026mm oversized, which is .00102in, that should theoretically move the oil clearance up tighter to around .00202, and more in the middle of the range, correct? No "hidden" factors that would make it something else?
Just need a check on my math, looking at all these thousandths for so long now, I'm going cross-eyed... :clonk:
Thanks!
(This is what I get for buying a Ford truck...$1K+ rebuild only six months in on the 4.2 v6 ...damn you, torque to yield bolts!!!
Thanks!
