BBC Open or closed Chamber heads??
20K views 14 replies 12 participants last post by  540Hotrod
Okay I don't wanna start any arguements but what do you guys think is better? Running small domes (like .133) with closed chamber heads, or bigger domes (.250) with open chambers?? I'm aiming for a "semi streetable" 10:1 CR
I've found a guy who has a set of each for sale, but he says open or closed chambers is all personal preference.
What do you guys think?
#3 ·
Be careful!!!
I have .133 domes with the 101cc semi open chamber(290)heads and ended up at 10.5 so 98cc closed chambers will push that up even more.
I just finally worked out my detonation problem, you may have read my woes in other post.
Save
#4 ·
9 times out of 10 the open chamber will flow more when we're talking "old tech" big block Chevy stuff.
So I'd take airflow over combustion issues. You can't burn what never gets in there! You can get compression with smaller domes with a little miling. A .250-.300 dome isn't all that big considering the funky shape of a big block chamber/dome anyway. A dome that size isn't going to be blocking much anyway.
Always be sure to actually CC heads. I often find heads with much larger actual chambers than what the books list. Especially on this older stuff that may have had a few valvejobs. I had a set of 96cc heads that actually measured 115cc once! We had to mill them like crazy and install new valves to get chambers back in line.
JIM
Save
#5 ·
The best head is probably the one you own. If you are starting from scratch, don't bother with iron. It will get real expensive.
Save
#7 ·
i have direct comparasons for you. my 68 chevelle has 215 closed chambers my father in laws 66 elky has 049 open chambers. both heads were ported by the same guy. the setups are indetical except he has an auto and i run a 4 speed. we both have 10 to 1 motors he has .250 dome i have .125 dome he is 122cc i am 107 cc. the cars are both super strong he runs 11.21 at 120mph, i run 11.21 at 121 mph. it really is a toss up . the most important thing for you to consider in my opinion is if you ever change to a modern aluminum head they arepretty much all open chambers , so the open chamber pistons can stay in there and you would'nt have to buy new ones. that is what keeps me from going to aluminum heads my small dome. ray
#11 ·
I have run and experimented with both closed and open chamber heads of the square port type. I am not going to go into scientific details but open chamber heads have the overall advantage because of improved breathing. Chevrolet was looking for more power and this was achieved even with a slight dip in compression. If you already have a set of closed chamber heads it's not necessary that you scrap them. After all, you can open up the chambers by porting them a bit as I did.
G
#13 ·
I think the guy's pretty much agree that properly set up closed chambered heads can use slightly higher CR. and still run the poor gas we have now due to a slightly more eff. chamber vs the better suck, but the slightly poorer detonation resistance of the open chambered heads..
AND we can get a fight going on this if we want to really get on this topic so that's all I'm gonna say!!
pdq67
#14 ·
Thats what I think.
Unless you've got the peanut port heads, a big block chevy will run fast,
with open or closed, rectangle or oval port heads.
The breathing issue might have something to do with the displacemant of your engine too.
A guy with a 540 needs more air flow than my 396.
Save
#15 ·
For sure if you are scratch building a new engine design, a small chamber with flat top or even "inverted dome" or dished pistons will burn better.
But I'm a strong believer in airflow, and typically the open chambers flow more air. No matter how big the engine is, you need the most amount of airflow possible. I'm not talking about bigger ports, I'm talking about what gets past the valves into the cylinder. In fact, on a small bore motor like a 396, ANYTHING you can do to help get the air into the cylinder will help. Now this may only involve opening up the closed chamber heads around the valves some.
The newer design "closed chamber" type heads that all mfg's use are light years away from what we are dealing with. They have very shallow chambers that still allow LOTS of room around the valves for airflow, yet maintain small cc's.
Once again...you can't burn what doesn't get in there!
JIM
Save
