Hi Guys
Can someone tell me if this combo will work, if so how well? Other cam recommendations welcome. The car will be mainly a daily driver with occasional trips to the track. Do you think this is a low to mid 13 second combination? This combo will be going into a 71 Chevelle.
The specs on the car are:
Engine
1977 454 stock bottom end with 781 heads
525/525 224 310 Howards cam
Performer intake
700 DP Holley carb
Transmission
TH 400 with B&M shift kit
B&M 3000 Holeshot convertor
Rearend
12 bolt
Eaton posi
Richmond 390 gears
Lakewood traction bars
Exhaust
3" summit from headers all the way out the back
Engine
Performer intake
700 DP Holley carb
Transmission
Rearend
12 bolt
Eaton posi
Richmond 390 gears
Exhaust
