You give up a LOT of quality control when you go with a long block that you want serious or reliable performance out of - even more when you go with a turnkey engine. There's a reason they are price competetive - costs are cut somewhere. Where? Your guess is as good as mine, but if these purported "production" long blocks and engines were truly the same quality as a carefully machined and constructed custom engine, they would cost what those cost. Don't believe the bs. You have at best a 50/50 chance of getting a non-problematic product when you look at production turnkey. If you were going to go that route, go with a GM 502 or 572 and be done with it. GM has literally centuries of engineering and QC built into their manufacturing process. Those "other" guys have a name, some cnc equipment and whomever they can get for the best price to put them together. Heck, you may be getting an offshore rotating assembly without even knowing it.
If you are one of the lucky winners to get a problematic build, your visions of time-saving by going with a long block will vaporize as you realize you have a complete rebuild to do AFTER you get the first engine running and find the problems.
Save yourself some frustrations and get EXACTLY what you want. Find a good independent engine builder, select either a GM or Dart block and then follow the advice on how to build what you really want. You'll find that for the same money, maybe just a few dollars more, you'll get the highest quality build you can find - because you are right there with it while the machine shop and engine builder are spec'ing it and building it.
When I had to rebuild my 427 to a 434, there were things I thought I wanted that the engine builder absolutely would not use or do. Why? His experience with 100's of solid builds and years of what does and does not work. So, I listened and now the sucker just screams. BTW, when we tore the crate apart, it was absolutely shocking what we found - a schizophrenic mixture of midrange and bin parts and....well, to call it "machining" would be generous....
Bottom line: There are a bunch of great independents in your area(s) that will work their butts off to make you happy. Avoid the catalog route and get what you really want. Even if it's an awsome independent builder halfway across the country (like Lewis Racing Engines), it's not like those guys don't know how to crate up an engine and ship it to you....
Best,
Mike
