Please describe the process of changing ball joints exactly and in great detail. Also, please list, describe and recommend where to buy any special tools that might be required.
Yes, a quality hydraulic floor jack under the lower control arm, right under the spring pocket, will work fine. Don't use one of those cheap compact ones, you'll get hurt.Need more help:
I can't get the spring compressor to fit. So, is there a way to replace only the lower ball joint without a spring compressor AND while leaving the spring in? (which safety chains of course).
Listen to Skip, Stewart. He's done this job before. Do NOT lower the jack or the arm, raise the spindle and upper arm out of the way. You'll probably have to remove your steering tie rod ends to do this effectively. Best way to do that without damaging the boots is whacking both sides of the steering arm, where the tapered pin is going into, with two large hammers. The trick is to hit them at exactly the same moment. If you do, and do it hard enough, the tie rod end will pop right out, undamaged.Yes, it's possible - you're nearly there.
Once you've separate the lower ball joint from the spindle, you don't need to lower anything - raise the spindle (and the upper arm, still attached) up to clear it from the ball joint and the lower arm.
As long as the weight of the car is supported by a jack under the lower arm, the spring cannot come out of either pocket.
The press should be big enough. You should have the threaded yoke pointing down, with a large receiver cup on the end of it, open side towards the ball joint. The top of the C clamp, with the open hole, should be on the stud of the ball joint. You have to hook the open hole on the clamp over the stud first, then install the receiver cup last. If you don't have a big enough receiver cup, the press is too small. Look into the one from OTC that I posted earlier. It's big enough. Mine is a Snap-On, will do 1 ton trucks. The OTC will too.Can't get the press on---not big enough.
Now, what?
Detail, man. I need detail.
The ball joint press should come with 3 adapter tubes and two plates for the top and bottom to press the ball joint back in.No; There's no CSKs on the east coast.
I'm going to try a steel yard tommorrow and if that doesn't work, i'll trim the one i have down.
