B&M shift kit question
1.1K views 4 replies 4 participants last post by  71-307
I gotta 71 chevelle and a 400 bored 30 over sbc. I have a th-350 tranny and I bought a B&M shift kit. The motor is pushin about 400hp and the car is an everyday driver. I don't know about the compression or cam or anything like that. The rear-end is like a 3:07 or close to it. real high. I think this will keep my rpm's down. My question is should I put the RV/Heavy Duty or The Street/Strip in? I want it to run like low 14's or mid 13's if possible. What do you guys think I should do? All info appreciated!
#3 ·
Is it a transpak or just a shift improver kit? I install transpaks on level II, street/strip. I have installed a bunch of em and havent had a failure. Make sure you have an inch/lb torque wrench for the valve body bolts and follow the instructions to the letter.
Dave
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
68/72 chevelles
55/57/61 chevies
TC member #493
Never forget Earnhardt!
Save
#5 ·
Trans go is the way to go, it shifts better over stock underlight throtle but shifts alot harder under hard throtle and its really nice. o and stage II of cource
Save
