Anybody using Compushift Mini for 700R4?
2.4K views 4 replies 3 participants last post by  Olle
I just installed a 700R4 in my '69, and it's set up for a 1-wire connection. I'm probably going to use a simple switch or maybe a latching relay setup first, but it would be nice to have an entirely automagic lockup. Compushift Mini seems to be a really neat setup, since it's controlled by both speed and throttle position. I found several threads about the Compushift II being used with 4L80E transmissions, but nothing about the Mini used with 700R4.
So has anybody used the Compushift Mini, and how did it work out?
#3 ·
I looked at their website earlier today, and it seems like they are for electronic transmissions only. There are some cheaper setups that use speed only to control the lockup (like this one from B&M: https://www.jegs.com/i/B-M/130/70244/10002/-1 ), but the only controller I have found that uses speed and throttle position is Compushift Mini.
#4 ·
I have a 700R in my wagon behind a 468. I used a $99.00 electronic loc/up system. Run a 12 Vt. wire to the tranny, attach it to the oil sender from shift kit, Run the 12 vt. with to the other side attach to module..... DONE.
It shifts at 13--36--55--& loc/up. ( you can set shift points where you want them)
NOTHING in the cab. Just stick it in O.D. and drive. Drives & shifts like my 6 speed Silverado. NO vacuum lines, NO switches,NO relays, NO NUTTEN.
Easy for the wife to drive , Stick it in O.D. and GO !!!
So far 46.000 miles & NO issues.
Bob
