Hey guys,
I installed the Allan Grove low Alt setup (217L-Alt) on my long water pump BBC.
http://www.alangrovecomponents.com/Big_Block_Long_Pump.htm
I am hoping this will eliminate my alt belt from tossing problem. IT sure fits nice!
I used a CS-130 alt with the 12&6 clock mounting (you can order this alternator under a 1993 Suburban with a 454 listing). This is a little smaller casing so there is more clearance than a SI series. I don't know if the SI series would clear the manual box I am using.
I am using a 40 inch v-belt which is nice and small. I of course am using a manual steering box so this freed up a area to install the brackets etc..
