1 - 4 of 49 Posts
Use the EO/IC method and set each pair carefully. Also, note if the zero cylinder is getting full lift.
One step at a time. From the ground up.
Adjust them running. I have seen a good amount of valves adjusted too tight doing them with the engine not running. A friend of mine got me into doing this and you can hear what the engine wants for lifter pre-load that you can't hear with the engine off.
Meh, I donnow. The only time I've done it was on a SBC where I had cut a valve cover for this specifically. Otherwise it s a mess.
I've never missed with EO.IC one set at time. To the OP, if you havent done it before, find a TC budy near you. The shop defintely effed it up. The mill should have been purring after a valve adj.
Yeah, what up? Still no snow here in Buffalo, so still could road test it in MN?
The other data point I'll share is that when I swapped the 427 in, we literally left the 750 DP sitting on a porch rail while we swapped the 427 in for the 396. Although it fired fine, the throttle got really thin after say 2200. I chased my tail in a cirlce for a while until I took that carb apart and cleaned it out. Somehow a fleck of soemthing was clogging an air bleed. From sitting out in the open on a porch rail, so..... anything can happen. I Saran wrap carbs anymore to eliminate oddball anomolies.
Naw, the carb needs to be completly disassembled , cleaned out, and put back in line with a filter. No filter, no way.
1 - 4 of 49 Posts
