Hey guys, is this a solid set up? I bought a 69 Chevelle with a 468 with the following:
scat crank, forged pistons 10.5-1 on factory rods, solid lift cam, dbl roller chain, comp pro magnum stainless rockers 1.7 and moroso stud girdle mounted on 781 steel heads, stainless steel valves 2.19I ans 1.88E, hurricane single plane intake and Barry Grant 850 vac. carb. a 700R4 with 2800-3000 stall converter and sfi flex plate with a B&M pro stick shifter, 10 bolt Eaton posi with Richmond 4.10 gears
Also what does 781 steel heads mean? thanks for any assistance
