A/C system holds vacuum, but loses freon?
24K views 4 replies 5 participants last post by  doc j
I put my system under 29.0" h.g. vacuum for 1/2 hour. I removed the vacuum pump and it held vacuum for another half hour. The needle doesn't even budge, which to me should indicate a tight system. When I recharge it, it loses freon and stops working after about 3 days. I don't have a leak checker, and I don't see any refrigerant oil anywhere indicating where the leak might be. What types of conditions cause refrigerant leaks when the system is in use while still allowing it to hold a vacuum when not in operation?
Regards,
Mike
p.s. I originally thought that it might be a shrader valve, but have since replaced one. The system still holds vacuum with either shrader valve disconnected from the manifold gauge set.
#3 ·
If you don't have leak detector, ...might try checking with leak detecting liquid soap. (From ac supplier) System needs to be pressurized, obviously. Will get a little messy, but it washes off. Also, could be a leak in the evaporator, which is visually unaccessable. Might be worth it .. to have an ac shop use their detection equipment on it, and be done with it.
#4 ·
Have you added any green refridgerant dye to the system? Get a pair of those yellow goggles and the black light and you may be able to see where the leak is.
Could also be possible that your evaporator inside the car is leaking too.
