I am trying to assemble my 9 inch that I purchased from Moser. It has the Torino style big ends on the axle tubes that need 1/2" t-bolts. These bolts go in fine and axles, brake backing plate and the axle retainer slip on just fine. The problem is that the nut that goes onto the t-bolts is 3/4" diameter, and the hole in the axle flange to access the t-bolts is 1" nominal diameter (actually measured at 0.995"). The thinnest wall socket I can get is 1.02" diameter, which is obviously too large.
A call to Moser about this was made. They told me they only drill one hole size for either the 3/8" or 1/2" t-bolts, and their sockets fit just fine.
Perhaps I just got an axle with the access hole drilled too small. Anyone else have this problem? Should I take the axle to a machine shop and have them ream out the hole to a slightly larger size?
