1 - 1 of 8 Posts
your original post sounded like you were dealing with Phoenix transmissions on the governor and converter.
Are you?
Is the TV cable set at full pull at WOT?
If not, get a recalibration kit or find a vette/F body governor with lighter weights and go from there.
Lighter weights on the govenor will raise the WOT shift points.
Save
1 - 1 of 8 Posts
