TH400 should be able to handle a 383 just fine, the 4L80e also. The 4L60/700R4 is the successor to the Turbo 350 and about on par in terms of durability. Without knowing what your plans are for the 383 stroker I can't say what would be best. If you are doing a mild build, pump gas 383 then I'd say a Turbo 350 or 700R4/4L60/4L60E would be adequate. If you are doing a stout, special fuel blend 383 like my uncle's I'd say go with the TH400 or 4L80 or even an upgraded 700R4 or 200-4R
