I have a 67 distribution block on my 65 because I switched to a dual master. It appears the dummy light sensor area is leaking, has anyone had this problem? The nut seemed a bit loose so I tightened it but to no avail. I attached a picture with a red arrow drawn pointing to the leak. Hopefully this is something I can fix while it’s still installed I’d hate to have to pull it apart and replace the block.
