67 396 PS and Alt alignments
1.5K views 15 replies 5 participants last post by  Afirehawk1
Does this look correct?
The alternator belt is right on the ps dual pulley;
I bought a single groove ps pulley thinking it would line up; it lines up line the dual pulley second groove
#2 ·
Buy the AIM get the correct part numbers and buy the right pulleys. It’s fairly simple. The PS pump get a single grove stamped steel pulley and then at the crank there is a add on pulley that goes over the crank that a single belt runs.
#13 ·
The AC pulley is located between the alt pulley and the PS pulley on the crank. Not sure about a 67, but on a 66 it is a 2 groove pulley on the crank (alt & AC belts) followed by another single groove pulley for the PS belt. In other words there are 2 pulleys bolted onto the crank in order to make the 3 groove setup.
