1 - 9 of 9 Posts
Do they bolt in? as in I can shorten my rear by an inch by changing to a 66-67 rear?
Bolt right up. You need to use the upper arms from your 68-72 car. The lower arms are the same.
Oh yeah, one other thing. Your wallet may not like the price if you are looking for a 65-67 12 Bolt.
Why wont the upper arms cross over? I've got a 68 12 bolt I want to install in my 66 elco, do I need the uppers from a 68-72?
Glad I read this thread if so! Sorry for the hi-jack, but seems like you might have the same issue.
Thanks,
Brian
Not sure about El Caminos, but the length of the Upper arms is different on the 65-67 Chevelles. I believe the 68-72 Upper arms are longer.
Use the uppers from whatever car you're bolting into. If you're installing the rear into a 68, use the 68 uppers. The mounting points on the diff are the same, the locating points on the frame are what's different.
1 - 9 of 9 Posts
