1 - 10 of 10 Posts
br549
Discussion starter · #1 ·
If i swap a front sway bar from a 79 ws6 trans am (1 1/16 " for $10)to my 66 ss, will i have to drill holes spaced wider apart where it mounts to the underside of each fram rail? Also, will i need to use the part that mounts to the a arm from the 66 or the 79?
I think you will use the 66 mounting parts. I have a 1 1/8" bar and that is what I did. Just get 1 1/8" bushings for your original mounting shells and use the 66 "A" arm mounts (you can all the soft parts in polyurethane, polygraphite or rubber).
Pat Kelley
66 El Camino, daily driver
67 El Camino, STRIP/street
I put a Trans Am front bar on my El Camino, I used Energy suspension frame mounts and end links for a Chevelle. The frame mounts are universal, just take the measurement of your sway bar, mine was 1 1/4'.
Steve R.
I just bought one from a 77 Z28, and it's a 1.25" piece. $35, will bolt it up next week. maybe even Saturday... From what I heard, all the 2nd gen F-body front sway bars are a simple bolt in.
Save
1 - 10 of 10 Posts
