I have searched the forums looking for advice on installing new coil springs on my 66 Chevelle. I put one of them in and now the front is 3" higher than it was before. Before I go any further, I want to figure out what's going on. 3" is way too high for me. Anyway, after reading through the forums I see a lot of guys talking about clocking or indexing the spring on the upper and lower control arms. Well, the '66 only has an indent on the upper where the blunt end of the coil obviously goes. On the lower, there is nothing, no indent like the upper. There are, however, two holes, which I assume are drain holes but I see guys talking about how the end of the coil is supposed to go in between those two holes. If the top is sitting correctly in the indent, the bottom will never go in between the two holes. So, has anyone replaced the springs on a '66 that can toss some advice my way? If so, what am I doing wrong? I did notice the spring I bought has 11 coils, where the stock has 10. I cant see one coil making that much difference. If what I said above about the top coil resting in the indent of the UCA is correct, then I guess I just need to cut a coil off the spring. Any advice would be greatly appreciated. Thanks guys.
