Took my bench seat out to remove, clean & paint the seat rails. Discovered that the rear pedestal on both rails has been torch cut, shortened about 3/4" and then welded and riveted back together. As a result, the seat does look just a hair more reclined that what I think standard appearance is. I intend to get the pedestals back to their original height, unless someone tells me this was some sort of ugly factory modification and should be left alone.
Along with that, what is the most common practice for carpet padding over MegaMat/UltraMat foil backed type insulation in the floors? Is it standard 1/2" jute padding throughout over the mat? My intent is to have a quieter, cooler floor than original, but I am not freaking out about trying to achieve any extreme results.
Thanks!
Thanks!
