Hey guys, i've got a big question. I've recently acquired a L92 6.2L LS engine backed with a 6L80E trans (6 speed automatic) & have been researching a little about putting into my 67 chevelle. Now, as far as I can tell, no one has yet to accomplish this task, the buys over at www.v8tvshow.com started in a 66 GTO, but didn't have the time to do it, so they exchanged it for a 4L65E. Now, according to my research, the trans is quite larger, and will need to have the tunnel cut out & re-made. No problem there, but the problem I do have (mainly because I don't have any knowledge on the subject) is the drive line angle. To get the trans to fit, I believe the motor & trans assembly needs to be raised up about 4" to get the trans pan to rest flush with the frame rails. This is where my knowledge stops. What sort of issues will I run into with the drive line angle, drive shaft, rear end assembly. I have yet to actually put the engine & trans down into my frame (body is off), I want to go into this swap as prepared as possible. Feel free to treat me as an infant on the subject because I am. Any help is super appreciated!!!
