Hello guy I am going to build a 396 all I have is the block that I just dropped off at machine shop. I would like to get around 500 hp any recommendations on what to put in the lower end? Bigger block is not an option
Don't forget the corvette was a short water pump set up so post 70 chevelle parts won't work.But all that I have is a block no crank nothing else
It’s already 30 over and it seems like the hardest thing will be pistons would like to get around 10.5-1 compression I will buy new head AFR ? Cam, intake
And carb. I’m not in a rush I can get pulley , the place I got the block he has pulley and brackets. O AND HE HAD CHEVELLE PARTS.
