davis95
Discussion starter · #1 ·
1st, are the OPG repro lenses any good? 2nd, I went through one of my bolt buckets from the front-end teardown and have 9 of the chrome phillips-head screws that attach the lenses to the housings. I only need 4 but I don't remember if these same screws are used anywhere else on the car. I can't figure out why I have 9 of these. I had a few parts cars awhile back that I stripped and kept parts from, but don't remember obtaining extra turn-signal screws. Does anyone know if there are any more than 4 of these screws on the entire car? Thanks.
Thats way I use a ziplock bag and a marker when I do my tear downs, hate those "extra" bolts and screws. I used the OPG lenses that fit good compared to some if the brite work trim I bought.
My repro lenses would not line up perfectly with my worn out original housings. Nor would they line up with my new housing either. I had to slightly trim a corner of one of the mountings to get it to fit. You can really see it unless you lay on your back, look up at the bumper and see the where I sanded off the corner.
