Can someone please confirm the Diameter of the 168 tooth flywheel (big block 70 Chevelle)?
thanks, Dan
thanks, Dan
DZAUTO said:..............There is a 13in diameter, 153 tooth flywheel and a 14in, 168 tooth flywheel...............
DZAUTO thanks! Another queston, my flywheel measured approximately 14 (pretty sure) however, my clutch measures 10.5 in diameter. Does this make sense?DZAUTO said:REGARDLESS of automatic or manual tranny, there are only 2 sizes of GM flywheels (flexplates), 168 teeth-14in diameter and 153 teeth-13in. This measurement is across the teeth, it is not exactly 13 and 14in, but it is VERY close to 13 and 14in. There are no sizes in between. So, it is EITHER one or the other, PERIOD.![]()
CCH said:Dan:
After we spoke on the phone, I was on the phone with Red Roberts (McLeod) and I asked him about the 168 flywheel issue. Red said that 168 tooth flywheels can have different bolt pattern for 10 1/2 or 11" cltuch. If your bolt pattern on the flywheel is 11 5/8" (center to center) then that is for 10 1/2" clutch. If your bolt pattern is 12 5/8 (c to c) then that will take a 11" or 12" clutch
Thanks Herb, at least I know I am not going crazy. I am going change the flywheeel so that I can up grade to the 11" clutch, I am runny a blown 402 application and think it would be wise to go this route.Herb said:Dan,
So do I.
I have 168 with a 10.5 in. clutch behind a 400SB.
/herb
