Mortec --> 14092359...86-90...oval...OPEN...366T, 427T, Marked "HiPerf"
I know they have small valves (like 2.08) and even though they're off a tall deck truck engine, they have oval not "round" ports.
I also know that all the other heads marked "HiPerf" that I've ever seen are Rect. Ports...so whats up with these?
Anyone know anything else about these heads?? I've searched ALL over the internet and found very little about them. I'm running them right now (freshly rebuilt) but I'd like to know if it's worth the time and money to switch to a set of 781's? Aluminum heads are very nice and I know they'd probably help out with a few HP but I'm broke as a joke and can't afford them
Car is: 74 Nova (Guessing ~3,400 - 3,600 lbs ?)
Engine is:
454 +.30
KB 257 Pistons (-25.5cc / .250") (11.04CR w/110cc Chambers 10.2 w/ 119cc)
Comp XE 284H (284/296 240/246@.050 .574/ .578 110 LSA)
Edelbrock Air Gap Intake
AED 750 HO Carb
2800 Stall TH350 w/ 4.10
Right now, I usually drive it between 2,600 and 6,200 Rpm I have no valve float and don't find that the engine is running outta steam BUT I think that maybe going to a set of 781's might be better than what I have right now. This was the first BBC that I've ever built and first one I ever drove so I really have nothing to compare the engine to.
Any help/suggestions/advice is appreciated
Engine is:
454 +.30
AED 750 HO Carb
