I want to put a motor together for a 66 or 67 Chevelle and I run across Edelbrocks power packages and thought they looked pretty good. I am new to this place and would like any advise and thought on this. Is there anything diffrent that I could do to this motor to get more HP or is this plenty with this set up. With 540 HP under the hood of a 66 Chevelle what kind of time will I be looking at in the 1/4 mile. Thanks!
540 HP in a 454 Chevy (Oval Port)
540 HP in a 454 Chevy (Oval Port) with 539 ft/lbs of torque.
Edelbrock Performer RPM Power Package Components for
454 c.i.d. Chevrolet:
Edelbrock Performer RPM 2-O intake manifold..........................#7161
Edelbrock Performer RPM camshaft kit.................................#7162
Edelbrock Performer Series carburetor (750 cfm, manual choke)........#1407
Edelbrock Performer RPM aluminum cylinder heads......................#6045
Edelbrock timing set.................................................#7810
Edelbrock valve springs
(supplied with Edelbrock Heads; iron heads use #5762)................#5745
Edelbrock retainers
(supplied with Edelbrock Heads; iron heads use #9731)................#9715
Edelbrock valve locks
(supplied with Edelbrock Heads; iron heads use #9612)................#9615
Shortblock Components:
Bore........................................................4.250" + .060"
Stroke......................................................4.000" (stock)
Crankshaft............................................factory forged steel
Rods.........
factory (polished and shot peened) 6.135"center to center with ARP bolts
Pistons.................................................TRW #L2399 + .060
Rings......................Speed-Pro #R9590 + .065, 5/64" x 5/64" x 3/16"
Head Gaskets................................................Fel-Pro #1017
Test Engine Specs:
Main Bearings (clearance)...........Michigan 77 #MS 829 H (.0026"-.0035")
Rod Bearings (clearance)............Michigan 77 #CB 743 H (.0022"-.0025")
Piston Wall clearance............................................. .0065"
Ring End Gap clearance.................top ring .018" - second ring .014"
Rod Side clearance................................................. .020"
Compression ratio...................................................9.6:1
Ignition and timing...........................36° @ 3000 RPM + MSD 6 A box
Headers.............2-1/8" Primary, 32" long - collector 3-1/2"- 10" long
Edelbrock Performer RPM Aluminum Cylinder Head Specifications
Intake port volume..................................................290cc
Exhaust port volume.................................................100cc
Combustion chamber size.............................................110cc
Crane roller rocker arms.........................................13750-16
Intake valve size..................................................2.190"
Exhaust valve size.................................................1.880"
http://www.edelbrock.com/automotive/index.html
Edelbrock retainers
Rods.........
Test Engine Specs:
