Ok hey guys...I'm moving up to a solid roller cam and was wondering what you all think i should build since i have to pretty much tear my motor appart for new rods anyway.
Rigt now i have a 400 block with a 350 crank...its .060 over yields 383 cubes (377)
I have a 350 block that is .030 over in my garage that is ready for a build...i could make a 383 out of it...
or
use the 400 block and make a 408.....
The cam i'm going with is Harolds(lunati's)...
Lunati 501D3LUN, 310/314 at .020, 279/283 at .050, .640"/.640" lift, 106 LSA
Car is a 70 nova, 3050 lbs w/o driver
getting a cage this winter
th350
12bolt 4.56's moving up to a 5.38 with a spool
what would i gain/lose with any of these combos. I know the 377 should be better for the drags because of the unshrouding of the valves with the big bore/short stroke. But would it be easier to build a 400?
Just curious what you guys would think.
Ed
or
th350
Ed
