He got back to me and said they are 601 castings. Mortec says they are 53cc combustion chambers. From what I have been reading that would put me at 11:1. I'm preeeeety sure that tired old bottom end would not be happy with that. Is there any easy way to get this CR down to something pump-gas-able? Thicker head gaskets? That just sounds scary on its own.
This is not the final engine for the car, but I'm hoping for some simple upgrades that will make it a bit more fun than the 2bbl and low low compression it already has. I'll be adding 4 bbl and intake as well as one of the cam recommendations I hope to get from another thread that will start at that time
The HAMB thread about the 307 recommends a few different cams as well.
That's where I am. Trying to figure out if I want that high of a CR. I'm also assuming that the bottom end is OK. The odometer reads 00946, so it's either 100946, 200946 or 300946 miles
