Well my new motor will finally hit the dyno tomorrow or Friday. Anyone care to make a guess what it's going to make?
The combination:
GenVI GM block 4.500 bore
Wolfplace balanced rotating assembly, Scat forged 4.25 crank, Scat h-beam rods w/ARP bolt upgrade, Mahle pistons. 11.4 to 1 cr.
Brodix custom oval raised port castings cnc ported by Weld Tech w/ matching Brodix HV2019 Dominator intake fully ported. 2.300 int.1.88ex. valve job, bowl blend and intake porting by Dave Jack Cylinder Heads.
Straub solid roller .757/.709 lift 266/271 duration on 108cl
Isky EZX lifters
Jesel shaft rockers
Stefs Heads Up oil pan
GZ SuperPro vacuum pump
Lance Patton 1100 cfm Dominator
Head flow #'s
http://mob1226.photobucket.com/albu...TUT/2D2BCC73-0127-4719-9C81-69293961FAAD-2790-000001FABC2A3E3D.jpg?t=1366848522
The combination:
Isky EZX lifters
Jesel shaft rockers
Head flow #'s
