1 - 20 of 28 Posts
steelcomp
· Banned
Didn;t want this to get overlooked in the other thread, so I thought I'd start a fresh one.;)
Finally got some results on these from the customer but it doesn't really tell the whole story. The engine was chassis dyno'd before and after and according to the dyno, we put almost 100hp to the rear wheels, all things considered, but I know this is short of what's actually there.
These went on a 427 in a 69 Impala for a customer in NY with a ported Vic Jr and a Straub 3 lobe hyd. roller cam and I set the valve train up at my shop. The engine was wheel-dyno'd before the changes at 423 rwhp and the conditions that day were 67*, 13% humidity, 29.51 baro. The ported heads, intake and cam netted a gain of 65 rwhp with a best pull of 488 rwhp with conditions of 90.6* 33% humidity and 29.69 baro. On the first tesst they were also using a fan through the hood scoop which they said was worth 6hp; they didn't do that on this test. Given the differences in conditions I'd say we could be looking at possibly a "corrected" ~85 rwhp gain. That would be 508 rwhp X 1.2 = ~610 @ the crank. The problem lies in the fact that the dyno shows the engine peaking at 6200rpm and going pancake flat to 6900. We know for a fact that this engine is not making peak power at 6200rpm...more like 6800-6900 and closer to 670hp @ the crank. It's either a converter problem, or the tires are spinning, but none the less.
Click on the pic below and listen. This thing is pissed off!:mad: :D
Sounds great, did they get to the track?
You're right...that is one angry Mo-Fo!!! Love it!!
How much compression? I've got a soft place in my heart/head for 427's....good ones just seem to run better than they are supposed to!
JIM
That thing sounds insane :beers:
Sounds almost weird like a flathead Ford well maybe not a flathead, certainly not at an RPM a flathead would never see. It does not sound like most 427s, esp the L88 style I am so accustomed to.
Nice work! Man, I'd like another 85 hp please! But I reckon Scott's customer has more in port work alone than I have in my old school 427 longblock in total! In fact, my engine may have been less!
Customer got some track time this weekend. First time out did not change anything from old set up. She has lost a .1th in 60ft and gained .3th in ET and 4MPH. 69 Full bodied caprice all iron went a 11.31 at 118MPH. She is spinning at both gear changes and shifting at 7000 rpm. Footbraking at 2600 rpm. 4.88" gear and 8" stall 5500.
Customer is very happy and car was a favorite at Ateco this weekend.
Chris, I'm guessing she may weight somewhere around 4100lbs?
Anyway, it is a very nice build to all involved.
Scott, can I ask how much head work like this would run me? you can PM if you`d rather.
Anthony as a very satisfied Foxwell customer try to work something out with Scott on some head work for you, you will not regret it...:thumbsup:
Trey,
Yes I would guess her at that weight also. She is "plump". Traction is the issue now. Tires have about a season and half on them but Scott I wanted him to start from where he left off so we would have a direction to go to.
With the customer in the car it is 4700#'s.
JIM
Exactly my thoughts too
Excellent effort guys and kudos for the owner stickin with the 427 :) .......has that Straub sound at full tilt :) ....and a squishy cam too !!!! Compression ??
1 - 20 of 28 Posts
