It appears that after depressing the brake pedal on my '72 SS (power disc/drum), the pedal returns slowly, which leaves the brake switch engaged for a few additional seconds. Should the boost pressure return the pedal instantly? Is this an indication that I have a minor leak in booster? The car stops normally, the brake switch itself has been replaced, and the switch bracket bolted near the top of the pedal arm has been tightened.
